I have a Survey123 field survey which has been used to submit field surveys to a feature layer hosted on AGOL.
In one of the fields which is a list look-up, but which can also be populated from a CSV file in the Media folder... I have a few records which I'd like to change the value of.
I presume the records I want to change have been populated from the CSV (for an existing asset), as they don't match the items in the list I have for surveys of 'new' assets.
The problem is no matter how I try I can't change any of the values in this field..
- tried Survey123 site - data tab
- tried item view in AGOL and double-click on the rown in table. appears to work but reverts to original value.
- tried adding the feature layer to a webmap. Pop-up has edit option.. I can change the value, but no option to save.
- tried adding the feature layer to ArcMap desktop. layer is non-editable?
Any ideas appreciated.
Malcolm
