I am using a custom URL to open Survey123 on Windows with the GlobalID and other key fields filled in already. After some trouble with the registry, the application opens fine using these two workflows: 1.) Collector (online) -> Survey123 and 2.) AGOL -> Survey123. However, the linked GlobalID field only works when AGOL is the starting point. I've attached screen prints. The other fields fill in as expected, but GlobalID remains blank, which causes problems for the related records. In the Survey, the fields that are _parent are notes, and WELLGUID is the foreign key.
Here is a snippet of the url:
<a href="arcgis-survey123://?itemID=f8a153e4d0954c8b864d12f4434a4e43
&field:GlobalID_parent={GlobalID}
&field:WELLGUID={GlobalID}
&field:WELLID_parent={WELLID}
&field:RECHARGE_parent={RECHARGE}
&field:TYPE_parent={TYPE}
Thanks for any help you can give!
