I created a survey123 about a month ago and our users said we need some additional options in the dropdown, so I went into survey123 connect and added them, then published. If you are in the survey the locations show up and you can select them.
But then when I go to the survey results either in the data page or the web map something weird is going on.
The data appears in the attribute table:
but then when I go to publish the report the question is not there and is blank? Also in the webmap, the attribute is simply blank
It is only doing this for the few additional options I added to the dropdown recently. The original options are working just fine.
Please help. I need the final data by Friday.
