Hi
We have had Survey 123 integrated with Collector for the last 3 years. The links have always been configured to the Survey 123 app to pass through fields and pre-populate the survey. Recently we ran into issues on our devices so we need to switch the links to open the surveys in a web browser. It all seemed to be working fine until we realized that the hidden fields weren't getting passed through.
We have two 'hidden' fields that are passed from Collector to Survey 123 - these are an address identifier and feature class name. These are essential because after the survey is completed, the feature class is updated with the information from the survey. This drives symbology on the maps.
Because the feature class name is null, there is no way for our systems to know which layer to update with the survey data.
Here is an example of the link that directs to the Survey 123 App (currently working and passing through all data):
arcgis-survey123://?itemID=1234567&field:ID={ID}&field:FULL_ADDRESS={FULL_ADDRESS}&field:FC_Name={FeatureClassName}
Here is an example of the link that directs to the Web Browser (preferred option but isn't passing through all the data):
https://survey123.arcgis.com/share/1234567?field:ID={ID}&field:FULL_ADDRESS={FULL_ADDRESS}&field:FC_Name={FeatureClassName}
The Survey 123 data is linked to a table in SQL server, and there are SQL scripts that run every 10 seconds to update any records from the Survey 123 SQL table into the correct Feature Class. The two fields aren't getting passed through to the SQL tables or on the web version of Survey 123. The survey was created in 2017 using Survey123 Connect but I'm not sure which version it was originally created in.
Do we need to recreate our surveys in a different version in order for this to work? We would like to use the web browser version of Survey 123 if possible.
