I am using the Java ArcObjects API for ArcGIS 10. I have a FeatureClass object for a feature class table within a file geo-database. I want to remove all of the features so am using the featureClass.deleteSearchedRows(null) call. I use "nul" as the query filter in order to get all of the items. I have tested this on a test file geodatabase and it works fine. When I try to use it on another local file geodatabase that already existed, it does not. The code runs without any errors but when I go to view the feature class in ArcCatalog, all the rows are still there. Initially I thought that maybe it was a permissions issue but I would have figured that a permission error would have been thrown. The problem here is that because no error is being thrown, my code wants to go on and re-populate the feature class with other items but if the feature class still contains the previous items, I have a problem. Any clue as to what might be happening?
Thanks - Peter
