I used the ESRI template to create a basic QML/C++ Test app to learn QML. I wanted to then experiment adding my own custom scale bar to the map (I'm using Runtime 100.1 with QT 5.8) and was attempting to follow the guidance in: https://community.esri.com/thread/201990-scale-bar.
I created the scale bar; however, when I attempt to assign it from my main qml file when its running I receive the error: "Unable to assign ESRI::ArcGISRuntime::MapQuickView to QMLMapView" at the map:mapview line below.
The main QML looks like:
import QtQuick 2.6
import QtQuick.Controls 1.4
import Esri.Test 1.0
Test{
width:800
height:600
MapView{
anchors.fill: parent
objectName: "mapView"
ScaleBar{
map:mapview
I've googled the error and looked over ESRI forums, but don't see any mention of this error.
No code was changed from the sample on the C++ side or the scale bar itself. What am I missing?
