I've read the API content for the esri/dijit/Geocoder and didn't see anything in regards to maxCharacters allowed for user input. Does anyone know how I can set this in my application? One of our network staff tossed in roughly a million characters into the search box and slowed the server to a crawl for a few seconds. Is there any way we can set a Max Characters sort of like the way there is a minCharacters property in the geocoder api?
Thanks so much. Here is the code the way I have it now.
// Creates the Geocoder using the RTC Streets Geocoder
var myGeocoders = [{
url: locatorUrl,
placeholder: "Search By Local Address"
var geocoder = new Geocoder({
map: map,
autoComplete: true,
arcgisGeocoder: false,
geocoders: myGeocoders
}, "search");
geocoder.startup();
var geoSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE,
18,
new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
new Color([255, 153, 153, 0.5]), 8),
new Color([255, 0, 0])
// Modify the symbol user to show geocoded location
geocoder.on("select", function showLocation(evt){
var point = evt.result.feature.geometry;
var graphic = new esri.Graphic(point, geoSymbol);
map.graphics.add(graphic);
