I'm trying to use the default printing service from an Enterprise 11.5 portal in a ExperienceBuilder application. When selecting my utility service in the print widget it does not load, but immediately shows a message saying "service is not available".
I've gone through the Organization > Settings > Utility services and checked the printing service URL there as well and it's set to Esri default. When I try to add the URL it says it's invalid or inaccessible.
I'm using this format: https://<organization.com>/arcgis_local/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task
Note here that the server site uses "arcgis_local" - could that be an issue?
I've checked the Server Manager, the service is running and set for Synchronous execution. I stopped and started it, still got the same message.
Would appreciate any suggestions - must be something I'm missing.
