Enterprise 11.5, Windows 11...i have a feature report template i built using the documentation at https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereport-choice.htm
i have a multi-select question and i have all available options listed in the report...the ones that get selected should have a check box, the ones that do not should have an empty box...the syntax i am using is this (for example):
${mine_type | checked:"Placer"} Placer
when the report generates, those that were selected appear correct, but those that were not have a weird unicode character instead of the empty box
The font in the report is calibri...when the report generates, if i select the font, and just select calibri again (even though the template is already in calibri), it appears as it should
Has anyone experienced something similar? This seems to have become an issue either since we went to enterprise 11.5 or windows 11, not sure which, as this report doesn't get run much in the winter and both occurred close to the same time recently.
