Hi all,
I am looking for guidance or documentation on a specific publishing workflow to share web feature layers to an Enterprise GDB in ArcGIS Enterprise system.
Current setup:
- ArcGIS Enterprise 11.5 (Server and Portal are federated)
- Enterprise Geodatabase running on PostgreSQL
- Note: We do not have an ArcGIS Data Store installed in this environment.
Our users want to share data from ArcGIS Pro as a Web Feature Layer.
Usually, when using "Reference Registered Data," the data stays in place.
However, in this scenario the source data is local (or not yet in the GDB),
and we want the publishing process to automatically copy/upload the data into
our PostgreSQL Enterprise GDB so it becomes the backend storage for the service.
Normally, "Copy All Data" defaults to the ArcGIS Data Store.
Since we don't have the Data Store installed, we want to know if there is a way
to designate the Enterprise Geodatabase as the "Managed Database" for the hosting server
so that it acts as the destination for these layers.
Questions:
1) Is it possible to use an Enterprise Geodatabase (PostgreSQL) as the default destination
for hosted-style publishing in Enterprise 11.5?
2) If not, what is the recommended "best practice" for users to move local data from ArcGIS Pro
into the GDB (via the Server) during the sharing process?
Any links to documentation or advice would be greatly appreciated.
Thank you and best regards.
