I am attempting to set up a data store on a client's Enterprise portal. I am using a connection to an enterprise geodatabase that the client is also hosting.
After I upload the SDE connection file and click Next, I get an "Error" message after the validation test. I used my browser's developer tools and found that the actual error message is "The connection property set was missing a required property or the property value was unrecognized. Connection was attempted with an older version of SQL Server client communications software that is not supported."
This leads me to believe that the issue is possibly due to ODBC drivers not being installed on the client's machines hosting Portal/Server/DataStore components, but I'm not exactly sure. Unfortunately, I don't have access to the client's hosting machines, so I'm unable to check or do anything myself.
I am wondering if anyone here has a better idea or could possibly confirm my suspicions. I wanted to try to figure out the steps needed to correct this issue, so that I can pass them on to the client.
Any assistance would be appreciated!
