This survey will let the user select a monitoring site from a select_one with a field. Depending on the site selected, I want to use pulldata to pull several attributes to fill questions (e.g. lat/long but in a text box so alternate locations can be entered). The following appearance line works:
autocomplete search("UMR_Mainstem_Fixed_2025?url=https://services3.arcgis.com/wPPMe5A6TnW0nbD4/arcgis/rest/services/UMR_Mainstem_Fixed_2025/FeatureServer/0")
However, I've been unable to get the pulldata to update based on the answer to that selection:
pulldata("@layer", "getRecord", "https://services3.arcgis.com/wPPMe5A6TnW0nbD4/arcgis/rest/services/UMR_Mainstem_Fixed_2025/FeatureServer/0", ${UMR_Mainstem_Fixed_2025})
...pulls the first record from the hosted feature layer. A read-only calculation and a latitude text entry follow. ${fixed_data} is the 'name' of the main pulldata line above:
pulldata("@json",${fixed_data},"attributes.SITE_ID")
pulldata("@layer", "getValue", "attributes.LAT", "https://services3.arcgis.com/wPPMe5A6TnW0nbD4/arcgis/rest/services/UMR_Mainstem_Fixed_2025/FeatureServer/0", ${UMR_Mainstem_Fixed_2025})
Both are populated with the attributes of the first feature layer record when the survey is opened. Choosing the select_one option makes both lines blank.
I'm unsure where to troubleshoot next - how do I use the initially chosen select_one choice to query the correct row in the target table?
