Hi everyone,
I have a local ArcGIS Pro project where I’ve collected different symbols created using Military Tools. I’m trying to publish it to a portal. The first step I took was copying the data from a local geodatabase (GDB) to an SDE, applying a web dictionary, and publishing it as a Map Service. Everything works properly. However, when I try to publish the data as a Feature Layer for further editing on the portal, I get an error from the editor widget that says, "You don’t have any permission to edit data." Other data from the SDE database, which wasn’t created using Military Tools, works correctly. Does anyone have any ideas?
Thank you.
