ArcGIS Pro 3.4.0
If I add a slow item (drag-and-drop or "Add to current map") from the Catalog pane to the map, such as a georeferenced image, then it takes 30 seconds for anything to happen in the map. I often wonder if Pro is doing anything. Is it adding the image to the map? Or did my drag-and-drop not work, and I should try again?
As far as I can tell, there's no indication that Pro is thinking in the background in this scenario. The mouse pointer doesn't change, and there is no progress bar or progress icon in Pro showing that the image is loading.
Could that be changed so that we know when Catalog is thinking?
