Can you publish a feature service (as opposed to a map service) from Pro if the data lives in a file geodatabase rather than an enterprise geodatabase?
I am trying to do this, and when analyzing before publishing, I get Error 00134: "Layer's data source is not supported" for all the layers.
All the layers come from a single file geodatabase that is stored in a folder on the same ArcGIS Server that all of our services are published on. That is, the data and the service would be on the same server.
I searched Esri documentation about this question and couldn't find an answer that seemed clear to me.
I also found this Esri Community post from 2016 that says it's not possible, but I'm wondering if things have changed or not.
I'm using Pro 3.0.3 and Enterprise 11.3 (I should probably update Pro...).
I don't need editing enabled; I just want a feature service because the layers have problems rendering in AGOL as a map service, and when I turn on feature access for the layers in Server Manager, the rendering problems go away.
