Hi all,
I made a minor tweak to a published survey created using Survey123Connect (adding a value to an external choice list used in a select_one question, stored in the media folder). When attempting to republish I am told that this will not affect the survey data, but publishing then hangs on 'updating form package'.
The change to the choice list may be a red herring, as reverting to the existing list and republishing a completely unchanged survey fails in the same way.
I have tried removing the local folder for this survey and forcing Survey123Connect to redownload this, which works fine, but then attempting to republish this (without making any changes) fails in exactly the same way.
I can find a previous forum page suggesting this can be caused by moving files around in AGOL, but I have not (knowingly) moved anything.
There are no error messages, so I'm at a bit of a loss as to how to diagnose the problem - has anyone had a similar issue in the past or can make any suggestions? I don't want to recreate the survey to make the minor tweak, as I don't want to lose the existing collected data.
Thanks a lot!
