We have published a survey in Portal using Survey123 Connect version 3.18.123. This hosted layer, Utilities Work Order, uses Experience Builder's Survey widget to pull data from several feature services into this one survey. These services reference our ArcGIS Enterprise 11.1 sde that is Branch Versioned. One of these services, Water Meter, contains a domain with three asset types: Water Meter, Water Irr Meter, and Auto Flush Meter. We are able to submit surveys for the domains Water Meter and Auto Flush Meter, but receive the following error message when trying to create a Work Order for Water Irr Meter:
[{"id":0,"addResults":[{"success":false,"globalId":null,"error":{"code":10500,"description":"Database error has occurred."},"objectId":null}]}]
The field lengths match in the survey and the hosted feature, and I have set the bind::esri:fieldType to null and tried removing the type entirely. So far, this is the only service affected, and only one domain choice out of three in the service is affected.
We have been using this survey without issue for several weeks, including work orders for Water Irr Meter. We cannot figure out why this issue is occurring, and why it only affects one domain choice in a single service. Anyone have some insight?
