Has something changed recently with Public shared surveys so you can no longer edit and resend a sent survey?? I know this may not be a common workflow, but I have several public shared surveys where it is understood that the sender may need to on occasion make corrections to their sent survey. This has always worked in the past but recently I've noticed that the survey field app now throws an error and will not send these surveys. There is not error message it just references the survey instance fields. I have double and triple checked all the permissions and sharing, and it still doesn't work. I also checked with a logged in user and it works fine for them. For now, I have switched these to allowing the "copy to new survey" option from the sent folder but this is not ideal. I'm wondering if anyone else has noticed this and maybe I'm just missing something?
Josh
