Hello, this is super urgent!!!
I’m encountering an issue with saving edits to a feature layer in ArcGIS Field Maps, the function is meant to change the symbology of the feature once edited using the "Unique Values" primary symbology. The error message is: "Something went wrong. Edits could not be saved: Failed to fetch."
My Setup:
1. ArcGIS Pro:
- Configured attribute-driven symbology using 'Unique Values'.
- Published the layer with 'Use symbol types defined by the layer' checked.
2. ArcGIS Online:
- Editing is enabled on the feature layer.
- Layer is shared with the appropriate groups.
- Error occurs when attempting to edit any feature attribute.
Troubleshooting Steps Taken:
1. Verified feature layer permissions and field settings.
2. Checked the feature service REST endpoint for issues.
3. Ensured a stable internet connection.
4. Re-published the layer.
5. Tested with a new simple feature layer; issue persists.
Request for Help:
Has anyone faced this issue or can suggest a solution for the "Failed to fetch" error when saving edits in the ArcGIS Field Maps?
Thank you
