I have a field map with a point layer and when a user selects a point, the pop up contains a link that launches survey123 and automatically fills in some of the survey fields based on information from field maps using the field:fieldname parameter. I assumed that the location of the point in field maps would be used as the location of the entry in survey123, but instead it uses the user's location. Is there a way to use the field maps point location as the survey123 location?
