Based on the sample data below I am trying to split each comma separated value in `MUNICIPALI` column to a new as shown in desired output. However, I am getting an error that `Projects_City` cannot open, it does not exist, but then I thought line 6 and onwards will create it. How can I fix this issue? On a side note, the comma separated values are a lot more than the sample data. For, example, one of them rows have 18 or something comma separated values so, will line 10 work for that?
Code:
import arcpy
# Import the surtax projects geodatabase table subset
in_df = r"O:\MyProject.gdb\Projects_City"
out_df = r"O:\MyProject.gdb\Projects_City_Updated" # Doesn't exist, expect it to be created in line 6
fldlst = ["OBJECTID", "PRJID", "MUNICIPALI"]
with arcpy.da.InsertCursor(out_df, fldlst) as insertCursor:
with arcpy.da.SearchCursor(in_df, fldlst) as searchCursor:
for row in searchCursor:
for attrbPart in row[3].split(","):
insertCursor.insertRow(( row[0], row[1], row[2], attrbPart))
Error:
File "o:\path\SplitCommas2Row.py", line 6, in <module>
RuntimeError: cannot open 'O:\MyProject.gdb\Projects_City_Updated'
Update
After creating the table, please see updated code below, I am getting the following error, how can I fix it?
Code:
import arcpy
# To allow overwriting outputs change overwriteOutput option to True.
arcpy.management.CreateTable(
out_path=r"O:\MyProject.gdb",
out_name="Projects_City_Updated",
template=in_df,
config_keyword="",
out_alias=""
fldlst = ["PRJTID", "MUNICIPALI", "ZIPCODE"]
Error:
File "o:\SplitCommas2Row.py", line 22, in <module>
IndexError: tuple index out of range
Sample Data:
| OBJECTID | PRJTID | MUNICIPALI | ZIPCODE |
| 1 | 1 | A | 1 |
| 2 | 2 | A, B | 1,2 |
| 3 | 3 | A, B, C | 1,2,3 |
| 4 | 4 | A, B, C, D | 1,2,3,4 |
| 5 | 5 | A | 1 |
| 6 | 6 | C | 3 |
Desired output:
| 1 | 1 | A | 1 |
| 2 | 2 | A | 1 |
| 3 | 2 | B | 2 |
| 4 | 3 | A | 1 |
| 5 | 3 | B | 2 |
| 6 | 3 | C | 3 |
| 7 | 4 | A | 1 |
| 8 | 4 | B | 2 |
| 9 | 4 | C | 3 |
| 10 | 4 | D | 4 |
| 11 | 5 | A | 1 |
| 12 | 6 | C | 3 |
