I am starting to build a new Survey 123 Connect that will be used to document what vehicles a GPS tracking device will be installed in. The Primary Key to the resulting Feature Layer needs to be the IMEI of the Device, the Secondary Key will be the Vehicle ID. I plan to use Connect so I can scan the Bar Code IMEI on each device.
Since I want this to be a collection tool I do not plan to use the inbox. But how do I control the issue of a potential duplicate primary key if a unit is moved from vehicle one to vehicle two and rescanned/inputted twice into the system?
TIA - -
