I have a form, screenshot attached, with a series of calculations to compute a final result. The first set of calculations work fine, but when I attempt to sum the results of two calculations then compute an average, the values are concatenated instead of computed. I tried setting bind esri field type to integer and also tried beginning each expression with int( as I found an article stating the calculation fields are saved as strings, so I assumed my final result fields are being treated as strings and concatenated instead of summed. The result stopped evaluating all expressions and provided results from only a single series of the expressions instead of summing and averaging the results. How can I correct the attached expressions to compute the sum and average of the 2 series of fields?
The xls form I am using is an older version, I pulled to from a previous survey to use as a template. Could this be causing the issue?
