Is anyone running a 10.5.1 ArcGIS Server and able to sync both directions? We have two different systems both 10.5.1 and neither are successfully syncing data. Data seems to upload from client without issue but the download is failing. This also causes a JobStatus.Failed to be returned. Because the job returns a failure, even though the edits did get sent correctly the replica does not think they were and so the outstanding edits just continues to increase and be resent.
I did have bidirectional sync working successfully prior to our upgrade to 10.5.1 so I have seen it work.
This is the message set returned from every replica we try to Sync. This happens with 10 replicas on my side and even more on our other system. I have looked through the AGS logs and there is not much there, other than it failed
2017-08-31 08:48:40,547 DEBUG - Job started.
2017-08-31 08:48:40,547 DEBUG - Creating delta database to path:
2017-08-31 08:48:40,547 DEBUG - No delta database to upload.
2017-08-31 08:48:40,547 DEBUG - Creating server job.
2017-08-31 08:48:40,547 DEBUG - Sending request start sync geodatabase on the server.
2017-08-31 08:48:40,547 DEBUG - Received response for start sync geodatabase on the server.
2017-08-31 08:48:40,547 DEBUG - Getting server job status.
2017-08-31 08:48:40,547 DEBUG - Sending request get server sync job status.
2017-08-31 08:48:40,547 DEBUG - Received response for get server sync job status.
2017-08-31 08:48:40,547 DEBUG - Delaying job status for 0 seconds.
2017-08-31 08:48:40,547 DEBUG - Delaying job status for 2 seconds.
2017-08-31 08:48:40,547 DEBUG - Delaying job status for 4 seconds.
2017-08-31 08:48:40,548 DEBUG - Sending request get server sync job status.
2017-08-31 08:48:40,548 DEBUG - Received response for get server sync job status.
2017-08-31 08:48:40,548 DEBUG - Delaying job status for 4 seconds.
2017-08-31 08:48:40,548 DEBUG - Getting server job status.
2017-08-31 08:48:40,548 DEBUG - Error while handling get server sync job status. Job error 500 Failed to synchronize.
2017-08-31 08:48:40,548 DEBUG - Job failed. Job error 22 User defined failure. Error while handling get server sync job status. Job error 500 Failed to synchronize.<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
