Hide a survey from the 'Download Surveys' list in the Survey123 Field App.
Use Case:
- Portal Group with access to 2 different S123 Forms.
- 1 form should only be used in the iOS Field App.
- 1 form should only be used in the Survey Widget of an Experience App.
I would like to prevent users from downloading the Experience S123 form to the iOS Field App.
Same user group requires access to both forms, so sharing alone cannot accomplish this.
FieldMaps has the option to 'Hide in Field Maps mobile' or set the web map item's "typeKeywords": ["FieldMapsDisabled"] parameter.
A comparable configuration option to disable download for each form under the Collaborate > Share Survey or Settings menu would be useful.
A comparable Survey123 "typeKeywords" option like "FieldAppDisabled" would be also be useful.
