Hello all,
I have a dashboard with an embedded survey that is used to edit survey responses. One of the functions of this dashboard/embedded survey is to track the training status of an employee. When the employee begins, they will select an option between 1 - 10 (select_one) depending on which training module they are on. I have a series of calculations set to be relevant depending on the selection of 1 - 10, and each selection of 1 - 10 has its own calculations.
The issue I'm running in to is when the calculate questions are not set to relevant, the data disappears from the dashboard. Is this to be expected?
Thank you for any help!
