At times during our field survey we will know the permit number, at other times we will know the record ID. I would like to pull data using either the permit number or the record ID, without having a prior question. At present I have the two select_one questions in a grid format (side by side), and can choose to pull data by permit number and record ID (image attached). I'm able to get the results I want, knowing not to select from both select_one questions. Is there a way to set up a select_one questionA or select_one questionB without answering a previous question?
Thank you,
Sage
