I have been using ArcPad (with an Archer2 mobile GPS unit) to do annual surveys of ponds. I divided the ponds up into 1/2 acre quadrants and filled out a survey form for each quadrant. When the survey for a quadrant was complete, the quadrant changed color, and the survey data was populated in a geodatabase by quadrant.
Now, I understand that ArcPad is being phased out, so I am trying to figure out how to replace it. Is Survey123 the replacement for ArcPad for this application?
If so, I have a couple questions about Survey123:
- How can I set up Survey123 so that it is visible real-time to the surveyor which quadrants have been completed? I have tried creating a WebMap that has the feature layer from the survey and a feature layer of quadrants, but that is not ideal. It is slow and requires an online connection, and it just shows a single survey point not a highlighted quadrant.
- How can I set up Survey123 so it doesn't have to reload the survey between each entry? In other words, when I use ArcPad, everything is offline and I just click on my new location to quickly launch a new survey form. With Survey123, when I click "Collect Data" it has to load a new survey form and downloads the map from ArcGIS Online. It is slow. I tried creating some offline map areas, but it doesn't seem to speed this process up.
- How do I make my WebMap show up faster in the map widget? I noticed that if I use the Basic basemap it appears fast, but if I use my feature layer, which is just a few quadrant outlines, it is very slow loading.
- In the map widget, how do I change the default zoom level?
