Hello Folks,
I am developing a Survey123 Form (in Survey123 Connect Advance form) where the surveyor will geolocate a series of lines by shooting a series of points via the software. The plan was to create a xlsForm that has:
- The user select the description of the points making up the line.
- The user then geolocates the point.
- And this series of inputs are nested within a Repeat.
The issue is, in it's current development every time a new step of the Repeat commences the description values have to be reentered, even though the surveyor is continuing to collect the same line with the same description. Is there a way in Survey123 to 'retain' the user's/surveyor's inputs in a series of repeats till the user inputs new values/description?
