The geopoint field is not populating with a map or coordinates in my Survey123 field app when disconnected from WiFi. It works fine when I'm connected to Wifi. Field maps and other apps that use Location Services are working fine when disconnected from WiFi, so it's clearly a problem with Survey123. The survey was published using Survey123 Connect. This worked fine last year using an earlier version of Survey123. I made some updates and republished using a newer version. Now it doesn't work. Any help would be appreciated.
I am using the following software:
Survey123 Field App: Version 3.15.146
Survey123 Connect: Version 3.15.165
iPad mini 6: iOS version 15.5
