I used Survey123 Connect to create two different surveys connected to the same feature layer; they share the same submission _url but have different form_IDs that point to different related tables in the feature layer. I want to add a link in my map pop up that opens the survey in Survey123 from Field Maps. The problem is within the normal structure of the Survey123 link (at least how I know how to create a link), there is no way to differentiate between which survey to open, which causes an error and neither survey to open.
Is there a specific parameter I need to use in my survey link to tell Field Maps which survey to open? The current link looks like: arcgis-survey123://?itemID=[itemID]&field:Intersection={Intersection}&field:Approach={Approach}&field:Insp_KEY={GlobalID}
