Good day @Scott_Aulen,
Hope all is well, so Insights does not support adding an integer column in a predefined filter as shown below.
Now a workaround for this is that I can change the datatype to string and then filter the values, and I can do a selection and show it on a map. But, I can't create other plots such as an histogram and any other exploratory statistics that does not support string data.
Is there a workaround to select an integer column in the filter, so that I can do other exploratory non-spatial analysis as well?
