My repeats section is not populate with data, but the form posting works from Survey123 Connect.
( I want to use the repeat section in update mode.)
Should I put allowUpdates=true in the same line where is "begin repeat" in the field bind:esri:parameters ?
Is there a parcitular parameter in the Settings sheet to set or somewhere else ?
Regards.
