Hello Everyone,
I'm new to this but really appreciate all that I've seen so far.
I was given a task to add a new entry in an existing dropdown on a form created with Survey123 Connect. There is no new field being added, just another choice in the dropdown is being added. Now that I know Survey123 requires me to update the form using the .XLS because the original was created using Connect I want to be sure I am doing this correctly. My steps are:
1) Go to the survey in my AGO organization.
2) Download the survey into my Survey123 Connect app on my machine.
3) Edit the .XLS to add the new dropdown entry.
And then here is where I am less confident.
If I publish the updated .XLS back up will 1) any data already collected by the form go away?, 2) will the link currently being used by my team change?, 3) will any dashboards that use the associated feature layers or services no longer know about the updated survey?
Likely these are very simple questions. I just don't yet have the understanding to know exactly what will happen. I hope with publishing it just update the survey and all continue to work flawlessly.
Thanks in advance!!
GR
