Hello, I have created my first survey using Survey123 connect and it uses a prepopulated data from a hosted feature layer and also has the option to add new data from the survey. When I add a new item the geopoint and username are correct and the information adds ok. However when I use the inbox to pull back a previous item that needs updating it does not update either username or location. All other entries are made manually these are the only 2 I need to have update from the device.
What do I need to do to make the survey automatically update these options rather than just display the previous value?
TIA.
