Hi All,
I am having a frustrating issue with one of my surveys which seems to be intermittent, but on closer observation became apparent when the device either lost connection (mobile data), or got logged out in the middle of a survey.
The problem starts when I notice that when I check a question which 'should' open up subsequesnt questions (relevent) don't open. In addition I can not navigate back (within survey repeat section) as it requests completing a required question (which is populated). I am then stuck for what to do except save survey in drafts. Even if I then reconnect / login the survey form behaves the same when I get to that section. The only way to resolve is to screenshot my previous recordings and then delete that survey record (from drafts) completely and start again.
When the device doesn't lose conection and remains logged in, there is no problem. Can anyone advise or know of this issue? I can and happy to elaberate if you nee more details.
