Re-posted from this comment on What's new in ArcGIS Survey123 9 February 2021) blog post
I'm seeing some unexpected behaviour using Survey123 Connect v3.12.230 and Survey123 on Android v3.12.274 with select_one questions with choice filters (bold red in below example).
When a choice filter is present the select_one selection lists won't display.
This isn't an issue in Connect v3.11.123 or Android v3.11.164.
type | name | label | required | required_message | appearance | default | readonly | relevant | calculation | choice_filter | bind::esri:fieldType | bind::esri:fieldLength |
text | ASSNBRI | Asset #. | | | | | yes | | | | esriFieldTypeString | 40 |
hidden | raise | Value can be used in field | | | | y | | | | | null | |
select_one classification1 | CLASSIFICATION1 | Utility: | yes | | minimal | | if(string-length(${ASSNBRI}) = '0', '', 'yes') | | | ${raise} = RAISE | esriFieldTypeString | 40 |
select_one classification2 | CLASSIFICATION2 | Asset Class: | yes | | minimal | | if(string-length(${ASSNBRI}) = '0', '', 'yes') | | | ${CLASSIFICATION1} = CLASSIFICATION1 and ${raise} = RAISE | esriFieldTypeString | 40 |
select_one classification3 | CLASSIFICATION3 | Asset Type: | yes | | minimal | | if(string-length(${ASSNBRI}) = '0', '', 'yes') | | | ${CLASSIFICATION1} = CLASSIFICATION1 and ${CLASSIFICATION2} = CLASSIFICATION2 and ${raise} = RAISE | esriFieldTypeString | 40 |
I tried changing the format of these expressions to the below, but this has no effect.
selected(${raise}, RAISE)
selected(${CLASSIFICATION1}, CLASSIFICATION1) and selected(${raise}, RAISE)
selected(${CLASSIFICATION1}, CLASSIFICATION1) and selected(${CLASSIFICATION2}, CLASSIFICATION2) and selected(${raise}, RAISE)
Choices:
list_name | name | label | CLASSIFICATION1 | CLASSIFICATION2 | CLASSIFICATION3 | RAISE |
classification1 | Stormwater | Stormwater | | | | y |
classification1 | Wastewater | Wastewater | | | | y |
classification1 | Water Supply | Water Supply | | | | y |
classification2 | Bore | Bore | Stormwater | | | y |
classification2 | Chamber | Chamber | Stormwater | | | y |
classification2 | Channel | Channel | Stormwater | | | y |
classification2 | Control System | Control System | Stormwater | | | y |
classification2 | Electrical | Electrical | Stormwater | | | y |
classification2 | Filter | Filter | Stormwater | | | y |
