We have a need to use the Living Atlas Terrain Layer in a Web Tool to analyze slope and aspect within a boundary. The overall model/scripts are rather complex, but the issue I have is simple. To use the Terrain Image Service I have tried creating a GIS Server connnection and providing the url for the Living Atlas Server. This used to work, but now the Living Atlas Terrain3D layer does not validate. However, the TopoBathy3D layer does. Is there a credential issue going on because the Terrain is also registered with Portal?
I've been experimenting with different data sources for the Living Atlas Terrain Layer by using the item registered with Portal, but that always fails to publish, siting an error with credentials.
Is using the Terrain layer supported in a Web Tool? What is the recommended approach for using it?
Should we register the Living Atlas layers with Portal, or does the web tool need to connect directly to AGOL?
