ArcGIS Pro 2.5: Utility network appears not to have tools to display flow arrows and set flow direction,
It would be great if the “display flow arrows” and “set flow direction” get available
ArcGIS Pro 2.5: How to display flow arrows and set flow direction in the utility network,
Jamal - coming soon in ArcGIS Pro 2.6 will be trace networks, which provide a way to directly convert a geometric network into a network that can be used in ArcGIS Pro. Primary use cases are for rail and water; it appears from your screenshots that you're working with water.
Built in to the ribbon will be Display Flow Direction:
Which will generate the flow arrows you're looking for.
There is also a Set Flow Direction geoprocessing tool that can be added to the ribbon, so I think in Pro 2.6 you will have what you're looking for.
Hope this helps!
Many thanks Kory. That would be great.
Do you have a simple network sample that you can share with us at which the flow is configured? I mean one can trace the upstream and downstream?
I think you should be able to use the geometric network from Water Distribution Network | ArcGIS Solutions for Water Again, this is Pro 2.6, so you would need to be working with the beta to test the functionality.
Dear Kory,
I tried the Arcgis pro 2.6.0 beta, and found out the this option is not available, please have a look below:
But if I go to option, I can find the ribbon, but how to display it on the main screen, why it is not appearing by default despite it is checked!!
Best
Majdoleen
Thank you for your input, I notice that to make the “Display Flow Direction” active, I need to build a trace network despite the fact I already have a utility network, which not make sence to me!
To build a trace network, I need to build a dataset that contains the edge and junction feature classes which are already created in the utility network, so I copy them and that make a duplication!
Is this the best practice to do that
Best,
Lubna
Correct. I did say that this will be available for Trace Networks in ArcGIS Pro 2.6. So if working with a Trace Network, you'll have what you need. But the idea requests this for Utility Network, which is why the idea is marked as Reviewed and not (yet?) in product plan.
Hi Kory,
Right. The idea for utility network.
Is this planned for enhancement in the upcoming release? 2.7?
Kory Kramer
Paul LeBlanc
is this planned in 2.8? this is a very baisc property
I apologize, but this is not planned as part of 2.8. And I'm not sure when exactly we will incorporate displaying flow direction in the Utility Network. It's not as basic a property as you might assume.
The Geometric Network maintained flow direction as an attribute (internally) for every edge in the network. The Utility Network derives flow direction on the fly, based on the locations of sources and sinks.
We have plans in the future to embed this information back into the network index, at which point, we could enable the display of flow direction. However, there are no immediate plans to support this. Keep in mind - returning flow direction arrows for all the data in your network, from a service, is not the smallest operation in the world. And we wouldn't want to implement such a feature which immediately causes significant performance issues. [GN was all direct-connect - so that was a bit easier to handle]
Thank you David for the input.
This functionality would provide much more sense as it displays the flow direction. It has been there in ArcMap for years and years and I was happy with it!
If it’s there then it’s optional for those who don’t like to use it due to performance issues
I appreciate the idea, and it is on our plans as a future enhancement.
I was just trying to set appropriate expectations with my response. I'm not sure when exactly it will become part of the Utility Network in Pro.
It is not as simple as just displaying it - its not as if we have this information stored, and are just keeping it to ourselves. It requires building the system to actually calculate and store this flow direction information (the UN derives this information on the fly during trace and analytic operations where directionality is required).
Again, on our future plans, but not specifically timed out, at this point.
@JamalNUMANMaybe not what your looking for, but Schneider Electric's Editor 11 series provides flow arrows over the Utility Network.
Is Schneider ArcFM is more powerful in terms of functionalities at the level of desktop and web than what we have in Pro?
Please do this and make this available via the utility network and be able to be seen on web applications. My utilities wants this for sewer and I have just had to make a secondary copy of my lines and symbology this out. It is kind of annoying that this is just not a simple turn on and off option.
It would great if this tool is added to Pro in the near future
JamalNUMAN
I have a suggestion for you, if it does it works.The electric line, copy and paste it and rename as the flow direction.
And change the single syblogy line as ArrowLine2.
than remove solid stroke.
You are able to see the direction of the line (if you are using the UN, your drawing direction must correct in terms of the flow direction ). When you need to see the direction, turn on/of the layer.
Thank you for the input.
In ArcMap, we could change the source\sink and thus the arrows are automatically switched to the new direction
But why it’s challenging to have this functionality available in UN?
Patiently waiting to get this functionality implemented!
How about 3.0?
This is a very valuable function that our guys in the field use daily, going from the geometric network to utility network almost seems like going backwards in this instance. Is there any update on the status of adding flow direction?
We are currently making the move to the Utility Network with our Electric, Water, & Wastewater systems. Flow Direction Arrows are a huge part of how we do business currently in ArcMap with the Geometric Network. This definitely needs to be an available option in the UN moving forward.
@DavidCrawford @MelissaJarman @KoryKramer has there been any movement towards adding this functionality to the UN in Pro?
@JamesRains Display flow direction—ArcGIS Pro | Documentation
@AyanPalit I have seen that flow direction is available on a Trace Network. However, we have a Utility Network and flow direction is not available.
To my knowledge, you can not have both networks on the same database. The functionality and detail of the UN is why we chose to go that route. Having flow direction is still very necessary, especially in our Electric System, and needs to be a part of the UN.
(https://storymaps.arcgis.com/stories/963ef30d778a4c549405bcbc1d3bad51)
@JamalNUMAN I'm guessing you still haven't heard or seen anything regarding flow arrows in the UN?
@KoryKramer @DavidCrawford @MelissaJarman @AyanPalit - We are in ArcGIS Pro 3.4 and this thread is going on 5 years now. Any progress with adding flow direction arrows to the Utility Network (not the Trace Network)?
Hate to be the squeaky wheel here, but has this problem moved any further towards implementation? I know it's been "under consideration" since 3-22-2021 yet nothing has made it to any of the previous releases. This is a critical workflow for our electric utility, which worked great in ArcMap, and would make my editors work so much easier. An update on this would be nice.
@JamesRains Thank you for being a squeaky wheel on this as it is also an important workflow for our electric utility. We feel like it is a needed element within the utility network. @AyanPalit
I agree its a necessary function. i wouldn't be opposed to esri providing a geoprocessing tool that flips lines in direction or trace result on downstream trace. Just a thought. @AyanPalit
Utility Network community with special mentions @HillaryBjorstrom @BraydenSAuten @JamesRains @JamalNUMAN
Please review the following resource and if this meets your use cases:
Introducing Tracing Using Digitized Direction in the Utility Network
Recommend giving this a try and identify remaining gaps.
@HillaryBjorstrom @BraydenSAuten @JamesRains @JamalNUMAN Thanks for the link however managing the digital direction manually seems unmanageable. are there any tools or workflows to catch these issues? like queries to select lines that need to be flipped based upon a downstream trace result? Currently i'm trying to use the enabled field as a trace stop and would like that to be the end of my feeder. my current configuration was created using the new migration to utility network tool.
@AyanPalit @HillaryBjorstrom @BraydenSAuten @JamalNUMAN Ayan - What you posted seems like it would work well for our gravity wastewater system, which happens to be drawn in the direction of flow. However, this will not work with our electric system due to switching changes that can redirect flow based on the Enabled field being True/False. I know that we can run a trace on the network to show connectivity but all the steps we have to jump through just to do that, especially when doing multiple edits, gets exhausting after a while. In ArcMap, if something wasn't connected properly, the flow direction arrow would automatically change to a solid dot. To verify you had it connected, all you had to do was click the Set Flow Direction button and it either changed to an arrow or stayed a dot, letting you know something was wrong with connectivity. Not having that simple function/tool has cost my editors a lot of time and effort.
@JamesRains Thanks for reviewing the option documented at Introducing Tracing Using Digitized Direction in the Utility Network
Looks like this meets the requirements partially - gravity-based networks. The use case for dynamic network with switching changes (electric) or pressurized hydraulic flow (gas) is important as well.
Now that Utility Network does have a network attribute called ‘FLOWDIRECTION’, that can be leveraged to support the dynamic use case. Perhaps, a script/attribute rule can be added to update the ‘FLOWDIRECTION’ and this will allow for the symbology to automatically refresh. Thinking out loud here so, additional gaps should be documented.
i like the attribute propogation idea. i will see if i can figure that out. any documention on setting up propogation would be greatly appreciated.
@AyanPalit Thinking out loud is good. It offers more topics and ideas to inspect and research. The FLOWDIRECTION idea sounds cool. However, according to documentation on Configure A Trace it specifically states, "Do not use this option if you are currently modeling flow using subnetwork controllers." Our ElectricUN is based on Subnetwork Controllers so it doesn't look that the FLOWDIRECTION would be an option either.
Please keep thinking out loud though and hopefully a solution can be found for adding Flow Direction Arrows into the Utility Network.
@AyanPalit @JamalNUMAN @BraydenSAuten @HillaryBjorstrom Some afterthoughts... We don't have any issues with tracing our Electric system in the Utility Network. We can set starting points and use the OOTB tracing along with custom Trace Configurations that work great. This has to do with (1) visual connectivity while editing and trouble shooting, (2) visual flow direction for quickly seeing how/where things are being fed.ArcMap:
ArcPro:
Again, I can't reiterate enough that this is a vital tool our editors used daily in the GN. When someone from the electric department or management would come over and ask us to show them how the system is being fed, we would be able to show them because of the Flow Direction Arrows. When the system wasn't flowing properly in our 3rd party modeling & OMS software, we could visually see where the problem was and fix it in a timely manor.Please help us all by getting this idea moved from "Under Consideration" to "In Product Plan".Thanks again!
Here's some good news on flow direction: Calculate Flow Arrows Add-In (Community Post)
Přihlaste se pro psaní příspěvků, sledování obsahu a další. Jste tu noví? Zaregistrujte se zdarma.
