I would like to see a widget created similar to the distress appearance that allows the creator of the survey question to configure the following options:
I have the same need.
The Distress widget is brilliant as extremely visual ; being able to customize it would make it more powerful and widespread. The colors used by default have implicit meaning (green: good ; red: bad / grren : low ; red: strong, etc), which is not always a good match with the numbers associated to them (by default: red: large value).
I would like to use a version of Distress that is low value = red = bad/low and high value = good = green. The use case is to register tree helath state or damage asseessment.
The likert widget matches the need, but is much less visual and therefore less powerful.
Přihlaste se pro psaní příspěvků, sledování obsahu a další. Jste tu noví? Zaregistrujte se zdarma.
