I have a couple guys trying to submit surveys and they will not submit. They are not getting error messages, both have tried restarting IPads and have tried signing off and back on again.
Hi Lori,
Can you provide any further information, for instance the version of Survey123 app and Connect in use? Was this survey published by Connect or Website? What version of iOS on the iPads?
Is there any error code or exclamation mark next to survey in Outbox? What happens when they press send?
Have you made any changes to the survey via Connect or Website recently, or changed permission of the feature service or groups?
Are other users with different devices able to submit successfully?
Phil.
Hello Philip,
A couple of people are getting the attached error code. I fixed the issue, updated and published it. I have had them update the survey on their IPads and they are still getting the error code. The others are trying to submit and it will save them but it will not submit. I have had them signoff/on and restart, but still not working.
We are using Survey123 Connect version 2.5.44 as far as an exclamation mark next to survey in outbox I will have to get with them on that.
I just this week took over this position with not much training, so I may be missing a step. I wasn’t told if there is something I need to do after publishing changes on survey. This is all new to me.
Thank you,
Lori Carroll
FSCC Program Coordinator
State Fire Marshal’s Office (SFMO)
O: 512-676-6813 | F: 512-490-1056
lori.carroll@tdi.texas.gov<mailto:lori.carroll@tdi.texas.gov>
SFMO Web Page - www.tdi.texas.gov/fire<http://www.tdi.texas.gov/fire>
Thanks for the extra information, it looks like there is something wrong with an expression in your survey, can you please attach a copy of your survey xlsx form. Thanks.
Hi Philip,
Attached is the xlsx form for the Survey. Please let me know if you need anything else.
