I've created and published my first survey and I used it to add a feature successfully. I see that in my ArcGIS Online content I have two feature layers associated with the survey, and that the feature I added is now added to both. Can someone explain or point me in the direction of documentation to explain the difference between the two layers? They have the same name except one has "_stakeholder" at the end. Screenshot of my Content attached.
Thank you!
Lisa
Hi Lisa
The '_stakeholder' item you're seeing is a hosted feature layer view. Survey123 uses views to manage access to your data. This technical article provides a description of the fieldworker and stakeholder views used by Survey123: FAQ: What are the Fieldworker and Stakeholder hosted views used for in Survey123?
Ismael's reply to this GeoNet post also provides some great info: Fieldworks and Stakeholders.
Hope this helps!
Jim
Jim,
Thank you so much for this helpful response!
Best,
Elisabeth J. Sedano, J.D., Ph.D.
Lecturer
Spatial Sciences Institute
USC Dana and David Dornsife
College of Letters, Arts and Sciences
University of Southern California
3616 Trousdale Parkway, AHF B57C
Los Angeles, CA 90089-0374
