I have a survey with a DateTime question. When I look at the data on https://survey123.arcgis.com the date is displayed, and you need to select a record then look at the popup pane on the right to see the time.
Is there a way to also display the time in the column?
Hi Rob,
Thanks for the suggestion - I've filed an enhancement to enable date/time display.
The enhancement has been implemented in the 3.1 release, you can now see the corresponding format for date, time and datetime question in the table of the Data page.
Thanks again for your feedback.
Excellent, thanks for the heads up. Looks good to me
