I am having an issue with the answers that I have prepopulated not showing up in Survey123 Online. I was wondering in this is a known issue or if anyone else is experiencing this issue, or if there is a way to solve it.
Hi Christine,
Setting default values in Survey123 Connect that are then used by the Survey123 web app should definitely work. What question type(s) are you setting default values for? Would you like to attach your XLSForm so I can troubleshoot further?
Brett
