In the guide below they're using Survey123 web builder to integrate survey123 and Collector. How do I implement this with Survey123 Connect using the following URL "arcgis-collector://?itemID=?".
Guide:
http://www.geomarvel.com/2019/01/29/collector-integration-with-survey123/
Hi Jordan,
Did you have a look at the Survey123 documentation here on integrating with other apps: https://doc.arcgis.com/en/survey123/reference/integratewithotherapps.htm#ESRI_SECTION1_BB1D69DBE8334B4BA0BE32376F2F7F55
If you add the following URL to a note question in your survey via Connect, you will be able to launch Collector from Survey123 and pass in parameters:
<a href="arcgis-collector://?itemID=35b1ccecf226485ea7d593f100996b49">Launch Collector</a>
Hope this helps.
Phil.
Hi Jordan Miller,
This is a nice workflow to integrate Survey123 for ArcGIS and Collector for ArcGIS. Thanks for sharing this blog post by GeoMarvel: Collector Integration with Survey123 | GeoMarvel
I think the best way to implement this is by following the step-by-step description in the blog post.
The item ID you have to add after "arcgis-collector://?itemID=" is the item ID of the webmap you have created in previous steps to prompt Collector to open for data collection within the designated webmap.
Good luck,
Egge-Jan
That guide is useful for learning how to obtain the itemID but it only shows users how to use the survey web builder which doesn't solve the issue at hand. All of our forms are built solely on survey123 connect so being able to implement URL links to connect to Collector on the excel sheet is the goal.
Hi, every one is it possible to integrate Collector in a Survey while doing disconnected data collection with the mobile device (no network/data). I see the URL prompts for webmap but what if the webwap is downloaded and working as local map. Hope I make myself clear.
Thanks a lot
Hi Cedric,
Yes, if all the data required in Survey123 and Collector is offline (already downloaded and stored locally) the URL scheme should work as expected offline. Have you tested already and are you having any issues?
If so, can you share the URL you are trying to use?
Regards,
I did not reach that point yet. Right now, I'm wondering why I cannot download a web map created when I published a Survey within Collector. I can see the actual map but I can't store it locally? What do I do wrong? I used to publish feature layer for Collector using Arcmap and it works so I guess there is something the publishing tool in arcmap does than survey123 does not. What is it?
Hello,
I have quick question, do you know how can at first start recording the track of person who is walking in the sidewalk by arcgis collector then at the end of walking the survey 123 pop up and he/she start filling the survey about sidewalk quality.
please help me thank you
