If not is this functionality planned for a future release?
ichivite-esristaff mentions the use of a repeat for photos in this thread: Multiple Photos in Survey123
Is that what you are looking for?
I think so, I'll give it a shot. Thanks for the quick response.
I'm still having issues setting up a repeat with a related table to store multiple images. I have the relationship class built, and have published a feature service with that related table available in the feature service, but when trying to publish my survey from Survey123 connect with the repeat referencing the related table by name I get an error that says the table cannot be found in the feature service.
I am using a feature service published from an ArcGIS Server which is then registered with ArcGIS Online. I am not using a hosted feature service or Portal for ArcGIS. Is this a supported workflow? If so what do I need to do to correctly reference the related table in the repeat of Survey123?
Thank you for your help with this,
Did you ever get this solved? I am at the same road block currently.
Hi Dylan,
This should be possible with Survey123. Are you creating the XLSForm using the Create New > Feature Service procedure, mentioned by Ismael in Working with existing Feature Services in Survey123 for ArcGIS?
To understand what's going wrong it would help to have the feature service information and XLSForm you are trying to match.
Yes the articles/blogs from Ismael and your feedback on other troubleshooting pages has been amazing BTW. I think I have read everything multiple times : )
I am getting this error when trying to publish the survey back into Portal using the Feature Service:
I then did some more searching and got to this point: ArcGIS REST API
I have a developer that can help me but I want to make sure on these "Repeats" I give proper directions to the developer if this fix is correct. Also I DevOped it via a Survey123 Connector into a Feature Service (Hosting) and pulled down the FGDB to take a look at the relationships. Below is the FGDB and I have rebuilt the "relationships" within SDE and made said Feature Service which gave me the above warning. I also want to make sure there is not a "data model issue" as when using "make survey from feature service" the images and repeats don't pull in to the Survey123 Connector Form. Even with other surveys with a simple "attachment" I tested "Image" doesn't pull in. I had no problem adding "image" in for simple attachments via the Survey123 Connector and successfully loading to SDE but the "repeat photo" data model is a bit more complex with relationships so want to confirm that aspect too is not giving a false warning. Even though the "repeat" did not pull in for the photos from the Feature Service I just mocked it up in Connector
