If not is this functionality planned for a future release?
ichivite-esristaff mentions the use of a repeat for photos in this thread: Multiple Photos in Survey123
Is that what you are looking for?
I think so, I'll give it a shot. Thanks for the quick response.
I'm still having issues setting up a repeat with a related table to store multiple images. I have the relationship class built, and have published a feature service with that related table available in the feature service, but when trying to publish my survey from Survey123 connect with the repeat referencing the related table by name I get an error that says the table cannot be found in the feature service.
I am using a feature service published from an ArcGIS Server which is then registered with ArcGIS Online. I am not using a hosted feature service or Portal for ArcGIS. Is this a supported workflow? If so what do I need to do to correctly reference the related table in the repeat of Survey123?
Thank you for your help with this,
Did you ever get this solved? I am at the same road block currently.
Hi Dylan,
This should be possible with Survey123. Are you creating the XLSForm using the Create New > Feature Service procedure, mentioned by Ismael in Working with existing Feature Services in Survey123 for ArcGIS?
To understand what's going wrong it would help to have the feature service information and XLSForm you are trying to match.
