Is it possible to have a hidden geopoint field that is just collected in the background? Possibly a calculate location in a hidden text filed?
The hidden geopoint is only available for the parent form. Repeats do not have the ability to have a hidden geopoint; you can add a geopoint to the repeat and have it be collected manually (you can restrict it to only capture from the GPS by setting the readonly property to 'yes').
Hi Brent,
Yes, a hidden groping field is built-in to Survey123- simply don't add a geopoint field explicitly. Survey123 automatically adds a hidden geopoint field that takes the device's location in the background.
I have a repeat in my form. Will it capture a location for each record in the repeat? Also is there any way to display the coordinates and calculate and display accuracy?
I tried the setting to read only but the map still shows and I really don't want to show the map. I would just like to see the coordinates and accuracy? Any thoughts on doing this?
Hello Brent,
I wanted to share that there is an enhancement which has been logged by technical support that may reflect the functionality that you are looking for. Please let me know if the synopsis below aligns with what you are looking for, and if you would like me to create a case on your behalf so that we can verify via phone or email.
ENH-000102235 : Survey123 - Provide ability to add multiple 'geopoint' questions in a survey, and have one of them AUTOMATICALLY collect the location information for where the survey was physically taken
Best Regards,
Brandon
Hi Brandon, Thanks for sharing the enhancement idea with me, I am not sure it would necessarily meet my specific need I basically have a form the collects some site information and then has several questions within a repeat (i guess it's kind of like a nested survey) I would like to capture the location each time the user completed the nested survey but I don't need them to see the map I just need the coordinate. Hope this makes sense.
Brent,
Thank you for sharing more about your workflow. I am sending you a private message which includes my contact information so that we can discuss your needs in further detail.
I think this comment should be marked as the correct answer, since the other one answers a different question.
