It looks like the media attachments are no longer displaying in the Survey123 'Feature Reports.' The same surveys/report templates were previously working with the 'Beta Reports.'
Has anyone else experienced this? Anyone know a solution?
I've tried using both syntax styles:
${operatorSignature | size:300:0}
${%operatorSignature | size:300:0}
No luck!
Hi Steven,
Can you please provide a copy of your xlsx form you used to create your survey, and also your word template. That way we can have a closer look to understand why it isn't working. Let me know if you can not share on this post, and I will send you my email address.
Regards,
Phil.
Hey Phillip,
Thanks for your prompt follow-up. I've attached one of the more simple XLSX/Feature Report templates that I'm working with.
Thanks, we will take a look and get back to you.
Thanks for the feedback and sharing the XLSForm and report template files.
From my testing, if I create a survey in ArcGIS Online (by removing the value of submission_url in your XLSForm) and use your report template, a submitted image/signature can be printed as expected in the report. Since the value of submission_url of the settings sheet seems to be an item in ArcGIS Enterprise, can you please confirm your survey is published in ArcGIS Enterprise?
In such a case, any attachment file stored in ArcGIS Enterprise does not have the "keywords" property supported which will lead to a known issue that you cannot reference an attachment file (image/signature...) in the report template by using the question name. That is being said, if your survey is in ArcGIS Enterprise, the syntax such as ${operatorSignature | size:300:0} will not work by design due to the limitation mentioned above, instead, blank value (a small white image) is expected for such a placeholder in the printed report. Would you mind sharing more details when you referred "The same surveys/report templates were previously working with the 'Beta Reports.' "?
Zhifang
Hi Zhifang,
I think the original reports I was using utilized ArcGIS online, not Enterprise. Perhaps that's the difference.
Is there anyway I can get the images/signatures to display in a feature report in ArcGIS Enterprise??
This is a crucial element that I assumed would transfer between online and enterprise, so any help would be greatly appreciated.
