hello, i am trying to build a process between survey123 (on portal 10.6.1) and integromat
i have this error message :
Function 'GetAttachmentUrls' finished with error! Unexpected token o in JSON at position 1
i had tested the process first on agol.
Hi Delaere,
This is apparently due to a difference in feature services in ArcGIS Enterprise and ArcGIS Online. We are looking into how to resolve this.
Thank you James,
i am waiting for the update.
Great thanks James, I was really excited to see the Integromat connector now supports Portal so looking forward to this being resolved.
Is there a way to disable integromat from trying to pull the attachment URL's that we could use at the moment?
Hi Andrew,
The problem seems to be resolved in 10.7.1.
I tried to ignore the error in integromat, but with no succes.
Hi Mikael,
Thanks for the reply - you managed to get it working at 10.7.1?
I'm using 10.7.1 (both Portal and Server) and hit the same error, even with surveys with no attachments. This is a feature service hosted in ArcSDE rather than a hosted feature service, maybe that's where the differences are introduced that aren't compatible with Integromat.
Will wait and see
Andrew
The Integromat connector currently checks for attachments in all cases. Based on the feedback, we are planning to address this in the future.
